SequenceOfReadAccessResult
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•group.presentValue
Esquema XML
  <xs:complexType name="SequenceOfReadAccessResult">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="ReadAccessResult" type="ReadAccessResult" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfReadAccessResult" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfReadAccessResult />
</Value>
Exemplo 2:
  <SequenceOfReadAccessResult>
    <ReadAccessResult>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <ListOfResults />
    </ReadAccessResult>
    <ReadAccessResult>
      <ObjectIdentifier>device-502</ObjectIdentifier>
      <ListOfResults>
        <ListOfResults_Item>
          <PropertyIdentifier>action</PropertyIdentifier>
          <PropertyArrayIndex>1237</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
              <Boolean>true</Boolean>
            </PropertyValue>
          </ReadResult>
        </ListOfResults_Item>
      </ListOfResults>
    </ReadAccessResult>
    <ReadAccessResult>
      <ObjectIdentifier>device-505</ObjectIdentifier>
      <ListOfResults>
          <PropertyIdentifier>activeVtSessions</PropertyIdentifier>
          <PropertyArrayIndex>1240</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
              <BACnetVTSession>
                <LocalVtSessionId>40</LocalVtSessionId>
                <RemoteVtSessionId>41</RemoteVtSessionId>
                <RemoteVtAddress>
                  <NetworkNumber>7643</NetworkNumber>
                  <MacAddress>FF</MacAddress>
                </RemoteVtAddress>
              </BACnetVTSession>
            </PropertyValue>
          </ReadResult>
      </ListOfResults>
    </ReadAccessResult>
  </SequenceOfReadAccessResult>
</Value>
Exemplo 3:
    <ReadAccessResult>
      <ObjectIdentifier>device-511</ObjectIdentifier>
      <ListOfResults>
          <PropertyIdentifier>apduTimeout</PropertyIdentifier>
          <PropertyArrayIndex>1246</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
              <Unsigned>1247</Unsigned>
            </PropertyValue>
          </ReadResult>
          <PropertyIdentifier>bias</PropertyIdentifier>
          <PropertyArrayIndex>1249</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
            </PropertyValue>
          </ReadResult>
          <PropertyIdentifier>changeOfStateTime</PropertyIdentifier>
          <PropertyArrayIndex>1251</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
            </PropertyValue>
          </ReadResult>
      </ListOfResults>
    </ReadAccessResult>
    <ReadAccessResult>
      <ObjectIdentifier>device-519</ObjectIdentifier>
      <ListOfResults>
          <PropertyIdentifier>controlledVariableUnits</PropertyIdentifier>
          <PropertyArrayIndex>1254</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
            </PropertyValue>
          </ReadResult>
      </ListOfResults>
    </ReadAccessResult>
    <ReadAccessResult>
      <ObjectIdentifier>device-522</ObjectIdentifier>
      <ListOfResults>
          <PropertyIdentifier>dateList</PropertyIdentifier>
          <PropertyArrayIndex>1257</PropertyArrayIndex>
          <ReadResult>
            <PropertyValue>
            </PropertyValue>
          </ReadResult>
      </ListOfResults>
    </ReadAccessResult>
</Value>
