SequenceOfBACnetLiftCarDoorCommand
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•lift.carDoorCommand
Esquema XML
  <xs:complexType name="SequenceOfBACnetLiftCarDoorCommand">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLiftCarDoorCommand" type="BACnetLiftCarDoorCommand" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLiftCarDoorCommand" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetLiftCarDoorCommand />
</Value>
Exemplo 2:
  <SequenceOfBACnetLiftCarDoorCommand>
    <BACnetLiftCarDoorCommand>none</BACnetLiftCarDoorCommand>
    <BACnetLiftCarDoorCommand>open</BACnetLiftCarDoorCommand>
    <BACnetLiftCarDoorCommand>close</BACnetLiftCarDoorCommand>
  </SequenceOfBACnetLiftCarDoorCommand>
</Value>
