SequenceOfBACnetCOVMultipleSubscription
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•device.activeCovMultipleSubscriptions
Esquema XML
  <xs:complexType name="SequenceOfBACnetCOVMultipleSubscription">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetCOVMultipleSubscription" type="BACnetCOVMultipleSubscription" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetCOVMultipleSubscription" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetCOVMultipleSubscription />
</Value>
Exemplo 2:
  <SequenceOfBACnetCOVMultipleSubscription>
    <BACnetCOVMultipleSubscription>
      <Recipient>
        <Recipient>
          <Device>device-501</Device>
        </Recipient>
        <ProcessIdentifier>2346</ProcessIdentifier>
      </Recipient>
      <IssueConfirmedNotifications>true</IssueConfirmedNotifications>
      <TimeRemaining>1236</TimeRemaining>
      <MaxNotificationDelay>1237</MaxNotificationDelay>
      <ListOfCovSubscriptionSpecifications />
    </BACnetCOVMultipleSubscription>
      <Recipient>
        <Recipient>
          <Device>device-505</Device>
        </Recipient>
        <ProcessIdentifier>2350</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1240</TimeRemaining>
      <MaxNotificationDelay>1241</MaxNotificationDelay>
      <ListOfCovSubscriptionSpecifications>
        <ListOfCovSubscriptionSpecifications_Item>
          <MonitoredObjectIdentifier>device-509</MonitoredObjectIdentifier>
          <ListOfCovReferences>
            <ListOfCovReferences_Item>
              <MonitoredProperty>
                <PropertyIdentifier>allWritesSuccessful</PropertyIdentifier>
                <PropertyArrayIndex>1244</PropertyArrayIndex>
              </MonitoredProperty>
              <CovIncrement>1245.567749</CovIncrement>
              <Timestamped>true</Timestamped>
            </ListOfCovReferences_Item>
          </ListOfCovReferences>
        </ListOfCovSubscriptionSpecifications_Item>
      </ListOfCovSubscriptionSpecifications>
      <Recipient>
        <Recipient>
          <Device>device-513</Device>
        </Recipient>
        <ProcessIdentifier>2358</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1248</TimeRemaining>
      <MaxNotificationDelay>1249</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-517</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>notificationClass</PropertyIdentifier>
                <PropertyArrayIndex>1252</PropertyArrayIndex>
              <CovIncrement>1253.567749</CovIncrement>
  </SequenceOfBACnetCOVMultipleSubscription>
</Value>
Exemplo 3:
      <Recipient>
        <Recipient>
          <Device>device-521</Device>
        </Recipient>
        <ProcessIdentifier>2366</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1256</TimeRemaining>
      <MaxNotificationDelay>1257</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-525</MonitoredObjectIdentifier>
          <ListOfCovReferences />
          <MonitoredObjectIdentifier>device-526</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>derivativeConstantUnits</PropertyIdentifier>
                <PropertyArrayIndex>1261</PropertyArrayIndex>
              <CovIncrement>1262.567749</CovIncrement>
          <MonitoredObjectIdentifier>device-530</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>deviceType</PropertyIdentifier>
                <PropertyArrayIndex>1265</PropertyArrayIndex>
              <CovIncrement>1266.567749</CovIncrement>
      <Recipient>
        <Recipient>
          <Device>device-534</Device>
        </Recipient>
        <ProcessIdentifier>2379</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1269</TimeRemaining>
      <MaxNotificationDelay>1270</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-538</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>faultValues</PropertyIdentifier>
                <PropertyArrayIndex>1273</PropertyArrayIndex>
              <CovIncrement>1274.567749</CovIncrement>
      <Recipient>
        <Recipient>
          <Device>device-542</Device>
        </Recipient>
        <ProcessIdentifier>2387</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1277</TimeRemaining>
      <MaxNotificationDelay>1278</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-546</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>inProcess</PropertyIdentifier>
                <PropertyArrayIndex>1281</PropertyArrayIndex>
              <CovIncrement>1282.567749</CovIncrement>
</Value>
Exemplo 4:
      <Recipient>
        <Recipient>
          <Device>device-550</Device>
        </Recipient>
        <ProcessIdentifier>2395</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1285</TimeRemaining>
      <MaxNotificationDelay>1286</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-554</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>localTime</PropertyIdentifier>
                <PropertyArrayIndex>1289</PropertyArrayIndex>
              <CovIncrement>1290.567749</CovIncrement>
              <MonitoredProperty>
                <PropertyIdentifier>manipulatedVariableReference</PropertyIdentifier>
                <PropertyArrayIndex>1292</PropertyArrayIndex>
              <CovIncrement>1293.567749</CovIncrement>
              <MonitoredProperty>
                <PropertyIdentifier>maxInfoFrames</PropertyIdentifier>
                <PropertyArrayIndex>1295</PropertyArrayIndex>
              <CovIncrement>1296.567749</CovIncrement>
          <MonitoredObjectIdentifier>device-564</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>minimumOnTime</PropertyIdentifier>
                <PropertyArrayIndex>1299</PropertyArrayIndex>
              <CovIncrement>1300.567749</CovIncrement>
          <MonitoredObjectIdentifier>device-568</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>modificationDate</PropertyIdentifier>
                <PropertyArrayIndex>1303</PropertyArrayIndex>
              <CovIncrement>1304.567749</CovIncrement>
      <Recipient>
        <Recipient>
          <Device>device-572</Device>
        </Recipient>
        <ProcessIdentifier>2417</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1307</TimeRemaining>
      <MaxNotificationDelay>1308</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-576</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>objectType</PropertyIdentifier>
                <PropertyArrayIndex>1311</PropertyArrayIndex>
              <CovIncrement>1312.567749</CovIncrement>
      <Recipient>
        <Recipient>
          <Device>device-580</Device>
        </Recipient>
        <ProcessIdentifier>2425</ProcessIdentifier>
      </Recipient>
      <TimeRemaining>1315</TimeRemaining>
      <MaxNotificationDelay>1316</MaxNotificationDelay>
          <MonitoredObjectIdentifier>device-584</MonitoredObjectIdentifier>
              <MonitoredProperty>
                <PropertyIdentifier>priorityArray</PropertyIdentifier>
                <PropertyArrayIndex>1319</PropertyArrayIndex>
              <CovIncrement>1320.567749</CovIncrement>
</Value>
