SequenceOfBACnetBDTEntry
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•networkPort.bbmdBroadcastDistributionTable
Esquema XML
  <xs:complexType name="SequenceOfBACnetBDTEntry">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetBDTEntry" type="BACnetBDTEntry" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetBDTEntry" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetBDTEntry />
</Value>
Exemplo 2:
  <SequenceOfBACnetBDTEntry>
    <BACnetBDTEntry>
      <BbmdAddress>
        <Host>
          <None />
        </Host>
        <Port>7634</Port>
      </BbmdAddress>
      <BroadcastMask>00010203040506070809</BroadcastMask>
    </BACnetBDTEntry>
    <BACnetBDTEntry>
      <BbmdAddress>
        <Host>
          <None />
        </Host>
        <Port>7635</Port>
      </BbmdAddress>
      <BroadcastMask>FF</BroadcastMask>
    </BACnetBDTEntry>
    <BACnetBDTEntry>
      <BbmdAddress>
        <Host>
          <None />
        </Host>
        <Port>7636</Port>
      </BbmdAddress>
    </BACnetBDTEntry>
  </SequenceOfBACnetBDTEntry>
</Value>
