SequenceOfBACnetAccessZoneOccupancyState
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•accessZone.alarmValues
Esquema XML
  <xs:complexType name="SequenceOfBACnetAccessZoneOccupancyState">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAccessZoneOccupancyState" type="BACnetAccessZoneOccupancyState" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAccessZoneOccupancyState" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetAccessZoneOccupancyState />
</Value>
Exemplo 2:
  <SequenceOfBACnetAccessZoneOccupancyState>
    <BACnetAccessZoneOccupancyState>normal</BACnetAccessZoneOccupancyState>
    <BACnetAccessZoneOccupancyState>belowLowerLimit</BACnetAccessZoneOccupancyState>
    <BACnetAccessZoneOccupancyState>atLowerLimit</BACnetAccessZoneOccupancyState>
  </SequenceOfBACnetAccessZoneOccupancyState>
</Value>
