lift.assignedLandingCalls |
Represent the current landing calls and their direction for the lift represented by this object. Each array element represents the list of assigned landing calls for the door of the car assigned to this array element.
A propriedade assignedLandingCalls do objeto lift pode ser lida e escrita utilizando um tag normal (IOTag).
lift-<endereçoDoObjeto>.assignedLandingCalls |
<tipo> = 59 |
<propriedade> = 447 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetAssignedLandingCalls>.
