Devices
Devices
This section contains information about the Device-type objects of the Hydraulic Model. The available devices on this section are the following:
Check Valve
Flow Control Valve
Generic Item
Level Control Valve
One-Terminal Measuring Point
Pump
Pressure-Reducing Valve
Pressure-Sustaining Valve
Shutoff Valve
Submersible Well Pump
Tank
Throttle Control Valve
Two-Terminal Measuring Point
Water Supply Point
Water Supply Well
