<< Click to Display Table of Contents >> ScreenObject |
Indicates to which Screen object the WaterExplorer object is linked. The default value of this property is null, that is, it is not linked to any Screen object. The next script contains an example of using this property.
Sub CommandButton_Click()
Set WE = Application.GetWaterExplorer("System1.Station1.Pump1")
Set WE.ScreenObject = Screen.Item("Pump")
