GetMeasurement
GetMeasurement
GetMeasurement(Terminal, Type)
Returns a Measurement object of type Type instanced in a device's Terminal. If this Measurement does not exist, returns an error. The Terminal parameter can be an empty String (in Measurement Group), "Measurements", which is equivalent to an empty String, "Terminal1" (in Terminal 1), "Terminal2" (in Terminal 2), "Terminal3" (in Terminal 3). In addition to these Strings, users can also specify integer values 0 - tsNone: In the Measurement Group, equivalent to an empty String or "Measurements", 1 - tsTerminal1: In Terminal 1, 2 - tsTerminal2: In Terminal 2, or 3 - tsTerminal3: In Terminal 3.
