<< Click to Display Table of Contents >> CommandAction |
An integer that indicates the type of Command sent. Possible values for this property are 0 - wcaNone: No Command, 1 - wcaOperate: Operate Command, 2 - wcaSelect: Select Command, 3 - wcaCancel: Cancel Command, or 4 - wcaOperateDelay: Operate Command with a delay. This is a read-only property.
