<< Click to Display Table of Contents >> AddToStation |
AddToStation(idElement, [idStation])
Adds the element indicated by the idElement parameter to the Hydraulic Plant indicated by the idStation parameter. If the value of the idStation parameter is a null ID ("{00000000-0000-0000-0000-000000000000}"), a new Hydraulic Plant is created in the element indicated by idElement. Otherwise, the indicated ID must exist previously. This method returns the added or created Hydraulic Plant.
NOTE |
For more information about the format of the idElement and idStation parameters, please check the ID property, common to all devices. |
