Scripts
Scripts
The language that Elipse Water Studio uses in its scripts is VBScript, a subset of the Visual Basic language developed by Microsoft. VBScript contains a fast, light, and portable interpreter, developed for use on Internet browsers and other applications using ActiveX Controls, Automation Servers, and Java Applets.
As seen before, scripts are linked to events of an object. However, to facilitate and increase development speed, Elipse Water already incorporated some of the most common actions that can be performed with scripts, through wizards known as Picks. Users can therefore define that a given event either executes a script, a Pick, or a combination of both, in a sequence that is also pre-defined.
Each View in Elipse Water Studio displays at least two tabs on its lower side, Design and Scripts, except for Database and Alarm Server objects, which do not have a Design tab. Objects and their child objects can be manipulated on the Design tab. To manipulate their scripts, use the Scripts tab. The available options on the Scripts tab are described on the next table.
Available options for Scripts tab
Option
Description
List of Objects List of Objects
Selects the object whose script is manipulated
List of Events List of Events
Selects the event to apply to an object
Script Script
Adds scripts linked to the event
Pick Open Screen Pick Open Screen
Adds an Open Screen Pick
Pick Open Modal Screen Pick Open Modal Screen
Adds an Open Modal Screen Pick
Pick Run Application Pick Run Application
Adds a Run Application Pick
Pick Load Value Pick Load Value
Adds a Load Value Pick
Pick Toggle Value Pick Toggle Value
Adds a Toggle Value Pick
Pick Print Report Pick Print Report
Adds a Print Report Pick
Remove selected script or Pick Remove selected script or Pick
Removes the selected script or Pick from the Actions List
Move selected script or Pick up Move selected script or Pick up
Moves the selected action up, in the sort order of the Actions List for the event
Move selected script or Pick down Move selected script or Pick down
Moves the selected action down, in the sort order of the Actions List for the event
AppBrowser AppBrowser
Opens the AppBrowser window
Find Find
Finds occurrences of a given text
Find previous Find previous
Selects the previous text occurrence in the results list
Find next Find next
Selects the next text occurrence in the results list
Replace Replace
Replaces the occurrences in the results list by another specified text
Compile selected script Compile selected script
Compiles the selected script, and shows its errors on the Messages panel
Compile all scripts from this event Compile all scripts
Compiles all scripts linked to an event
Compile all events from this object Compile all events
Compiles all events linked to an object
The execution order of actions is top-down. To change this order, use the Move selected script or Pick up Move selected script or Pick up and Move selected script or Pick down Move selected script or Pick down options. Use the Compile selected script Compile selected script option to verify errors in the specified script for the event. The compiler's error messages are displayed on the Messages panel, which can appear as a floating window or docked on the lower or upper side of the Scripts tab. Double-click the error to select it in the script.
Compiler messages
Compiler messages
