Keyboard Shortcuts
Keyboard Shortcuts
The next table contains the available shortcut keys on Displays.
Available shortcut keys on Displays
Shortcut Key
Description
0 (zero)
Fits the selected axis, vertical or horizontal
Application or menu key Application or menu key
Opens the contextual menu of the selected item on a Display
CTRL + 0 (zero)
Fits the horizontal and vertical axes
CTRL + DELETE
Removes a search point from a Display
CTRL + F6
Browse through the pens of the selected vertical axis
CTRL + G
Displays or hides the grid of a Display
CTRL + INS
Inserts a search point on the center of the screen, using the last search configuration from the current session or using the Label - Nearest mode if no search was performed
CTRL + K
Allows the mouse pointer to remain fixed on the screen during a search
CTRL + Left arrow
Moves the search point to the left
CTRL + Minus sign (-)
Executes a zoom out on the time axis
CTRL + Plus sign (+)
Executes a zoom in on the time axis
CTRL + Right arrow
Moves the search point to the right
CTRL + T
Displays or hides the Task Panel
CTRL + TAB
Toggles the focus between the Task Panel and the Displays
CTRL + Z
Executes a zoom back, when available
DELETE
Removes the scale from the plot area linked to the selected Display
Down arrow
Moves down the selected axis
END
Moves to the current period of time
ENTER
Selects the current Display or pen on the Task Panel
ESC
Clears the current selection
F6
Allows selecting vertical axes individually
F11
Enters the Full Display Mode. If this mode is already active, returns to the normal visualization
H
Displays or hides the Display selected on the Task Panel
INS
Adds a scale to the plot area linked to the selected Display
L
Adds or removes the link from a chart
Left arrow
Moves to the previous point on the time scale
Minus sign (-)
Executes a zoom out on the selected vertical axis
Mouse wheel
Scrolls the Display area horizontally or vertically
PAGE DOWN
Changes the time scale of a chart to larger units, such as from hours to minutes
PAGE UP
Changes the time scale of a chart to smaller units, such as from minutes to hours
Plus sign (+)
Executes a zoom in on the selected vertical axis
Right arrow
Moves to the next point on the time scale
SHIFT + TAB
Browse through the Displays, counterclockwise
Space bar
Plays or pauses a Display
TAB
Browse through the Displays, clockwise
Up arrow
Moves up the selected axis
