<< Click to Display Table of Contents >> Challenge IX |
TIP |
This action can be performed using a method from an E3Alarm object. |
1.Open Alarm_Screen.
2.Create a Command Button object near the E3Alarm object. If needed, resize the banner so that the Screen contains enough space for this button.
3.Configure this button's caption as "Acknowledge all".
Alarm_Screen
4.Select the Scripts tab of this object and insert a script .
5.Open AppBrowser and locate the AckAll method of Screen's E3Alarm.
AckAll method
6.Paste the expression and remove the optional Operator parameter.
7.If needed, add a comment above the line to identify its purpose.
Scripts tab
