GetPowerExplorer
GetPowerExplorer
GetPowerExplorer(ObjectPath)
Returns an object that allows configuring the window of a PowerExplorer object. The ObjectPath parameter indicates a Server object to which the PowerExplorer object is linked. In a script, users must use this method according to the next code.
Sub CommandButton_Click()
  Set PE = Application.GetPowerExplorer("SE1.Bay1.Breaker1")
For more information about methods and properties of this object, please check topic PowerExplorer.
