Operate
Operate
Operate([ActorID])
Executes an Operate action, in which the ActorID parameter is the user name. If omitted, it assumes Elipse Power Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if that method's call started at the server. For this action to occur, some conditions are expected:
The Unit's parent Command must have its Enabled property set to True
There must be no pending command operating in the Command Unit, that is, the ActionInProgress property must be set to 0 (zero, None)
The OnOperate's event script must be defined in the type of configured command Conversion
If the command Conversion defines the Auto-select before Operate option, the Select operation is executed first, and if it works, then the Operate operation is performed. This method waits for a feedback value up to the specified limit time if all the following conditions are met:
The script was successfully executed
The script was not canceled
The feedback limit time of the Conversion is not 0 (zero)
The feedback Tag's path is not empty
If the feedback value is not used by the Tag inside the limit time or the Tag's path is invalid, but it is not empty, this command is considered as failed. The next script contains an example of using this method.
Sub CommandButton1_Click()
  Set CMDUnit = Application.GetObject(_
    "Substation1.Breaker1.Commands.cmdBreakerPosition.Open")
  If CMDUnit.Interlocked = True Then
    MsgBox "The Command Unit is interlocked!"
  Else
    CMDUnit.Operate()
  End If
NOTE
The feedback value is only considered if its quality is not bad. Whether this action fails or works, the OnOperateFinished event of the configured conversion is executed, if it was defined.
