OnOperateFinished
OnOperateFinished
OnOperateFinished(ActorID, Failed, Canceled, FeedbackError, ScriptError, Aborted, Retries)
Event triggered when the Operate method finishes, successfully or not.
Description of parameters
Name
Description
ActorID
Informs to a script the name of the user passed on the ActorID parameter of the Operate method in a Command Unit. If omitted when calling that method, assumes Elipse Power Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if that method's call started at the server
Failed
When set to True, indicates that a Command Action failed and this was informed by the Failed parameter of the script of the OnOperate event
Canceled
When set to True, indicates that the Operate method ended prematurely
FeedbackError
When set to True, indicates that a Command Action failed because the returned value could not be read in the specified time-out. This may occur because the feedback Tag does not exist, because of a configuration error, or because the value contains a bad quality. For an incorrectly configured Tag, such as a syntax error, it is possible that FeedbackError parameter be immediate, that is, with no waiting time
ScriptError
When set to True, indicates that a Command Action failed because the script had an execution error at some point
Aborted
Indicates whether an Action failed because it was aborted, that is, if the Abort method was used
Retries
Indicates the number of the retry in which this Action was finished. A value of 0 (zero) indicates that this Action was finished without retries. If the value of this parameter is different from 0 (zero), this event is only executed after the last retry
