PrinterName |
Name of the printer used by the Line Printer object. The default value of this property is an empty String, that is, the Line Printer object uses Windows default printer.
NOTES |
•If this property is configured with an empty String and the UseDefaultPrinter property is configured as False, printing is not possible and the PrinterStatus property returns the value 0 (zero, psUnknown). •Windows default printer for the currently logged-in user may be different from the default printer used by E3 Server. This printer is identified by the icon |
