E3ApplicationLink
E3ApplicationLink
This section contains information about the methods of an E3ApplicationLink object. This object does not contain events nor properties associated to it.
NOTE
This object is only available in scripts of a Section Report object, which uses the Visual Basic .NET programming language.
To use this object in a script of a Section Report, users must create an instance of this object to perform an interface between a Section Report and Elipse Power, according to the next code.
Dim Application = Activator.CreateInstance(Type.GetTypeFromProgID("Reports.E3ApplicationLink"))
This instantiated object can then be used to access values of Tags, Screens and the Viewer object directly in a script.
