Blink |
This property determines that when the source is within this Row's interval, the property alternates periodically between values established in the Value and BlinkValue properties. The next script contains an example of using this property.
Sub CheckBox1_Click()
Screen.Item("Rectangle1").Links.Item("ForegroundColor")._
Item(1).Blink = Value
Item(2).Blink = Value
