This property specifies the value the property assumes when the source is within the specified Row's interval. The next script contains an example of using this property.
Sub CommandButton1_Click()
Dim Color
' Picks a color
Application.ShowPickColor Color, 0, 100, 100
Screen.Item("Rectangle1").Links.Item("ForegroundColor")._
Item(1).Value = Color
