E3Browser
E3Browser
1.Insert an E3Browser E3Browser on Event_Screen.
2.To configure data displayed by this E3Browser, open its properties window and select the Query tab.
3.Select Query1 and click Configure.
Query tab
Query tab
4.Select the Database containing the table to query.
5.Select the Alarms table.
6.Select the fields needed to display on screen. To display all fields from a table, select the row with an asterisk (*).
Alarms table
Alarms table
7.Open the Visualize tab and click Execute Query Execute Query to check this Query's result.
Execute Query
Execute Query
8.Click OK. After finishing this step, all fields listed on this Query are available in the E3Browser. Configure each field with the desired color, format, and size.
Field configuration
Field configuration
9.Execute the application and open Event_Screen to test this new functionality.
CHALLENGE XIV
Configure an E3Browser to display values No and Yes instead of 0 (zero) and 1 (one) for the Acked column, which indicates whether an alarm was acknowledged.
