ElipseX Libraries
ElipseX Libraries
Elipse Power features tools allowing to transform any object or set of objects of an application into a user library. The concept of user libraries, called ElipseX, comes from object-oriented programming languages, where several components can be shared among projects without developing every object again. Using Libraries in Elipse Power is highly recommended due to the productivity they bring to an application. Some of ElipseX advantages are:
Reusing code
Minimizing tests during development
Creating standard interfaces for developed objects
Reducing development time for new projects
Protecting project's content
Ranking objects
Using libraries is recommended in most applications.
Object libraries
Object libraries
