<< Click to Display Table of Contents >> Bay |
A Bay (EDBBAY) object does not contain events, methods, or properties associated to it, only general ones. These ones can be viewed on section Common Properties.
NOTE |
The class of a Bay object, regarding scripts, is different on the following objects: •On a Wind Power Plant, the class of a Bay object is EDBWINDPOWERBAY. •On a Photovoltaic Power Plant, the class of a Bay object is EDBPHOTOVOLTAICPOWERBAY. •On a Feeder, the class of a Bay object is EDBFEEDERBAY. |
