<< Click to Display Table of Contents >> WindowStayOnTop |
Indicates whether Elipse Power Viewer's window must always be on top of other windows. Default value of this property is False. This is a read-write property, but changing its value at run time does not change settings for an already opened Elipse Power Viewer, only for windows opened using Elipse Power Viewer's settings.
