TrackEvent
TrackEvent
TrackEvent(EventMessage, [Comment], [TimeStamp])
This method allows generating events manually via script. These events can be generated on a Elipse Power Viewer as well as on a Server, and are registered on an application's database table.
Parameters of the TrackEvent method
Name
Description
EventMessage
Contains an event's message, with a maximum of 200 characters
Comment
Contains additional comments about this event, with a maximum of 200 characters. This parameter is optional and, if omitted, assumes an empty String
TimeStamp
Indicates the date and time this event occurred. This parameter is optional and, if omitted, Elipse Power assumes the current date and time
This method only records events in case the Events Recording option in Domain Options is enabled. Events are recorded on a database table, which is also defined on the Event Recording settings.
For more information on Domain's Event Log, please check the Elipse Power User's Manual. The next code contains a usage example of this method.
Sub Button1_Click()
  Dim Tag, User, Comment
  Set Tag = Application.GetObject("IO.Inputs.IO01")
  If Application.ESign(Tag.PathName, , "Value Change", _
    Tag.Value, 1, User, Comment) Then
    If Tag.WriteEx(1) Then
      Application.TrackEvent _
        "Tag IO.Inputs.IO01 changed to 1 " &_
        "by the user" & User, Comment
    End If
  End If
