<< Click to Display Table of Contents >> DisableTaskSwitching |
If it is set to True, disables window switching on Elipse Power Viewer. Otherwise, window switching is enabled. Default value of this property is False. This property can be changed at run time by using the SetDisableTaskSwitching method.
