<< Click to Display Table of Contents >> PositiveFlowIn |
This property creates a relationship between the signal of current or power measurements and their flow direction. If it is True, positive values represent a current or power input (from a Terminal to a device), and if it is False, positive values represent a current or power output (from a Terminal to other external components). This property cannot be changed while this object is active.
