GetMeasurement
GetMeasurement
GetMeasurement(Terminal, Type)
Returns a Measurement object of type Type instanced in a device's Terminal. If this Measurement does not exist, returns an error. The Terminal parameter can be an empty String (in Measurement Group), "Measurements" (equivalent to an empty String), "Terminal1" (in Terminal 1), "Terminal2" (in Terminal 2), "Terminal3" (in Terminal 3), "GridTerminal" (in Wind Turbine's Generator Grid), or "GeneratorTerminal" (in Wind Turbine's Generator Terminal). In addition to these Strings, users can also specify integer values 0: tsNone (in Measurement Group, equivalent to an empty String or "Measurements"), 1: tsTerminal1 (in Terminal 1), 2: tsTerminal2 (in Terminal 2), or 3: tsTerminal3 (in Terminal 3).
