OnCommandEx
OnCommandEx
OnCommandEx(CommandInfo)
This event is triggered whenever any Command is executed, just like the OnCommand event. The CommandInfo parameter is a PowerCommandInfo-type object that contains all properties described on the next table, which are all Read-Only.
Properties of the PowerCommandInfo object
Property
Description
CommandInfo.ActorID
Name of the user sending this Command. It can be Elipse Power Viewer's user logon, "Anonymous" if there is no logged in user, or "System" if this method's call started at the server
CommandInfo.CommandAction
An integer that indicates the type of Command sent. Possible values for this property are 1: Operate, 2: Select, or 3: Cancel
CommandInfo.CommandUnit
Command Unit object receiving this command
CommandInfo.FeedbackValue
Indicates the return value configured in the Template, referring to the command operation sent. Possible values for this property are Operate, Select, or Cancel
CommandInfo.WriteValue
Indicates the writing value referring to the command operation sent. Possible values for htis property are Operate, Select, or Cancel
