<< Click to Display Table of Contents >> Abort |
Abort([ActorID])
Immediately cancels a pending action. This method is called automatically if the Command Unit is deactivated. The ActorID parameter is the user name. If omitted, it assumes Elipse Power Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if this method's call started at the server. Usage example:
Sub CommandButton1_Click()
Set CMDUnit = Application.GetObject(_
"Substation1.Breaker1.Commands.cmdBreakerPosition.Open")
CMDUnit.Abort()
