BackStyle |
This property defines a style for object's background. Available options for this property are 0 - fmBackStyleTransparent: Defines an object as transparent, that is, no object background is drawn or 1 - fmBackStyleOpaque: Defines an object as opaque, that is, background is drawn (default).
NOTE |
This property does no affect bitmap's transparency. Users must use an image editor such as Paintbrush, for example, to save a transparent bitmap. Not all ActiveX objects support transparent bitmaps. |
