<< Click to Display Table of Contents >> StrokeColorDeEnergizedUserDefined |
Indicates whether the color for a de-energized Feeder must be the color defined in the StrokeColorDeEnergized property (True) or else it must be the color defined in the StrokeColor property (False). Default value of this property is False.
