ImpedanceSource
ImpedanceSource
Enum Specifies which properties are used to calculate Branch's equivalent impedance. Possible values for this property are 0 - isCableAndLength (default): Uses the Cable and Length properties or 1 - isResistanceAndReactance: Uses the Resistance and Reactance properties.
