<< Click to Display Table of Contents >> EnableSynchronization |
Indicates, if enabled, that is, in True, that Elipse Power must also perform a data recording on a second database simultaneously, to improve security. If this property is enabled and there is a server in Standby mode, Elipse Power then performs a syncing between databases from both servers. The default value of this property is False, that is, syncing is disabled.
