FieldId
FieldId
Enum Unique identifier of the column of this Field on an E3Alarm. Possible values of this property are described on the next table.
Possible values for the FieldId property
Value
Column
Description
1
AckRequired
Event needs manual (True) or automatic (False) acknowledgment
2
Acked
Event was acknowledged or not
3
ActorID
Name of the operator that acknowledged this Event
4
ChangeMask
Not used and its value is always equal to 0 (zero)
5
ConditionName
Condition name, in case of an Alarm (Dead Band, Digital, Discrete, Level, or Rate of Change)
6
ConditionActive
Indicates whether the Alarm Source is in Alarm or not
7
Cookie
Value used internally by the Alarm Server
8
Enabled
Determines whether Alarm verification is enabled or not
9
EventCategory
Event category. For Alarms, possible values are Dead Band, Digital, Discrete, Level, or RateOfChange
10
EventType
Type of Event
11
Message
Text configured in the Alarm Source
12
Quality
Quality of the Alarm Source value at the moment of an Event
13
Severity
Value of severity configured in the Alarm Source
14
Source
Expression used to evaluate Alarm conditions
15
SubConditionName
Name of a sub-condition, if this is an Alarm Event
16
EventTime
Date and time of an Event
17
EventTimeUTC
Date and time of an Event, in UTC format
18
CurrentValue
Current value of an Alarm Source, as a floating-point number
19
AlarmArea
Name of an Area to which an Alarm Source belongs
20
AlarmSourceName
Name of an Alarm Source
21
EventTimeMS
Date and time of an Event, in milliseconds
22
InTime
Date and time of entering an Event
23
InTimeMS
Date and time of entering an Event, in milliseconds
24
OutTime
Date and time of leaving an Event
25
OutTimeMS
Date and time of leaving an Event, in milliseconds
26
AckTime
Date and time of acknowledging an Event
27
AckTimeMS
Date and time of acknowledging an Event, in milliseconds
28
FullAlarmSourceName
Full name of an Alarm Source
29
FormattedValue
Formatted value
30
InTimeDbl
Date and time of entering an Event, as a floating-point number
31
OutTimeDbl
Date and time of leaving an Event, as a floating-point number
32
AckTimeDbl
Date and time of acknowledging an Event, as a floating-point number
33
EventTimeDbl
Date and time of an Event, as a floating-point number
34
EventCLSID
Unique identification of an Event
35
ActiveSource
Active Measurement Source of an Alarm Source at the moment of an Event
36
Unbound
Indicates whether an Event is linked to an Alarm Source or not
37
Deleted
Indicates whether an Event was removed or not
38
AllowShelving
Indicates whether an Event allows shelving or not
39
Shelved
Indicates whether an Event was shelved or not
40
ShelvedTime
Date and time of shelving an Event
41
ShelvedOutTime
Date and time of unshelving or 0 (zero) if an Event is not yet unshelved
42
ShelveDuration
Duration time, in minutes, that an Event has been shelved
43
ShelveMaxDuration
Maximum duration, in minutes, that an Event can remain shelved
44
ShelveCount
Number of times an Event was shelved
45
ShelveMaxCount
Maximum number of shelvings allowed for an Event
46
ShelveActorID
Name of the operator responsible for shelving an Event
47
ShelveReason
Reason for shelving an Event
48
E3TimeStamp
Date and time of an Event occurrence in Elipse Power format
49
Suppressed
Indicates whether an Alarm was suppressed
50
SuppressedTime
Date and time of suppressing an Alarm
51
SequentialNumber
Sequential number of an Alarm
52
AlarmState
Current status of an Alarm
53
ShelvedExpirationTime
Indicates the programmed date and time for this Alarm to leave its shelving condition
