<< Click to Display Table of Contents >> StrokeColor |
Indicates the registered color of a device in the electrical model for the energized status. Default value of this property is white (RGB(255, 255, 255)).
NOTE |
For the Terminal object this is a read-only property and it reflects the value of this property on the device that contains this Terminal. |
