Playsound |
Playsound(FileName)
Plays a sound file whose path and name are indicated in the FileName parameter. This file must follow these specifications:
•It must be in a Windows sound format, with a .wav extension
•If this file is in a project, added using the Insert resource option, its name must be enclosed in brackets
•If a folder was created on a project and this file was added using the Insert resource option, this path must be enclosed in quotation marks, such as "c:\sound\ding.wav". If this file is on a local directory, its name does not need to be enclosed in quotation marks, it is enough to type a path, such as c:\sound\ding.wav
The next code contains a usage example of this method.
Sub InitialScreen_OnAlarm()
' If there is an active alarm, an alert sound is played.
' When this alarm is recognized, sound stops.
Set Alarm = Application._
GetObject("AlarmConfig1.Area1.AlarmSource1")
If Alarm.ActiveNACKAlarms = True Then
Application.PlaySound("[ringin.wav]")
End If
