<< Click to Display Table of Contents >> GetPowerExplorer |
GetPowerExplorer(ObjectPath)
Returns an object that allows configuring PowerExplorer's window. The ObjectPath parameter indicates a Server object to which PowerExplorer is linked. In a script, users must use this method according to the next code.
Sub
Set PE = Application.GetPowerExplorer("SE1.Bay1.Breaker1")
For more information about methods and properties of this object, please check the topic PowerExplorer.
