<< Click to Display Table of Contents >> ReportFailure |
ReportFailure(FailureName, FailureDescription, FailureWeight)
This method allows an application to report failures to a Server, which can be viewed by right-clicking Elipse Power's icon on Windows Notification area. When this method is used, Elipse Power's icon on Windows Notification Area starts blinking in red, indicating that a failure occurred. Reported failures are usually conditions preventing an application from working partially (problems with communication on a serial port, inactive network link, database without connection, etc.), and that usually cannot be detected by a Server. This method can be used in two situations:
•To warn a system operator about problems in a server
•To help the automatic Hot-Standby manager to decide which server is more suitable to execute an application
NOTE |
The ReportFailure method is only available in the Server. |
The ReportFailure method contains the parameters described on the next table.
Parameters of the ReportFailure method
Name |
Description |
FailureName |
Contains the failure name (user-defined). This parameter must be passed to the ClearFailure method when the application detects that this failure is no longer active. For example, "FaultCOM1" |
FailureDescription |
Textual description of the failure (user-defined). For example, "Communication failure at COM1" |
FailureWeight |
Defines a failure's severity (or weight). A value of 0 (zero) indicates a warning (no severity). Values greater than zero indicate failures. The greater the value, the severer the failure |
Example:
Sub TagSerialStatus_OnValueChanged()
If Value Then
' The tag value is True, application is on error
Application.ReportFailure "FAULT_COM1", _
"Communication fault at COM1", 100
Else
' The tag value is False, clears the failure
Application.ClearFailure "FAULT_COM1"
End If
