ColumnLayout |
Determines whether a Group Footer Section uses the same column layout configured in a Detail Section. If this property is set to True, the number of columns in a Detail Section reflects on the linked Group Header or Group Footer Section. Otherwise, its default configuration remains. Default value of this property is True.
