<< Click to Display Table of Contents >> RemoveScreenTab |
RemoveScreenTab(TabName)
Removes the tab indicated by the TabName parameter. Returns True if removal is successful, or False if the tab was not removed because it does not exist. This method generates a script error if the TabName parameter is the name of a default tab, Analog, Discrete, Commands, or Protections, or an empty String. Example:
Sub
Set PE = Application.GetPowerExplorer("Sub1.Breaker1")
PE.RemoveScreenTab "ChartTab"
