EuLow |
This property returns or configures the minimum value of the engineering unit of an Analog Measurement. The initial value of this property is inherited from the Analog Measurement Type's EuLow property. If the selected Analog Measurement Type does not exist, this property's value is zeroed. Default value of this property is 0 (zero).
