MaxRecTime |
Maximum difference, in seconds, between timestamps of two consecutive records stored in a database, that is, the maximum time without storing any data. For example, if a Tag is not varying its value, even then the current value must be written to the database whenever the number of seconds configured in this property is reached. This behavior can be disabled using the value 0 (zero). Default value of this property is 3600 (one hour).
