SaveFormulaValues |
SaveFormulaValues(UnitName, ValueName, [IgnoreErrors])
Saves the current values of Tags from an origin Unit into a Set of Values in the Formula table. This method contains the UnitName parameter, which indicates the name of an origin Unit, ValueName, which indicates a Set of Values to save, and IgnoreErrors, an optional Boolean that allows saving or not all values, regardless of errors in Formula links. If this parameter is omitted, those values are not saved. This method does not perform a check on limits if the Template contains an Absolute-type of restriction.
