Angle |
This property defines a rotation angle in degrees, counter clockwise, that an object must be rotated. This also applies to child objects of that object, respecting rotation limitations of each child object. An object rotates according to its center, which can be edited during this rotation operation. Default value of this property is 0 (zero, no rotation).
