DeletePoint
DeletePoint
DeletePoint(lIndex)
Removes the Polygon Point indicated by the lIndex parameter, which is the index of the Polygon Point in the Collection of Polygon Points. Polygon Points can only be removed from a Collection of Polygon Points with more than two Polygon Points.
