Direction |
Determines the spatial orientation of Barcodes. The available options for this property are described on the next table.
Available options for the Direction property
Option |
Description |
0 - ddbcLeftToRight |
Barcode's orientation is from left to right (default) |
1 - ddbcRightToLeft |
Barcode's orientation is from right to left |
2 - ddbcTopToBottom |
Barcode's orientation is from top to bottom |
3 - ddbcBottomToTop |
Barcode's orientation is from bottom to top |
