Zones |
Defines a set of Zones (TextZone) for an E2Text object. These Zones can be configured by accessing object's Properties window, on its Zones tab. Available options for this tab are described on the next table.
Available options for Zones tab
Option |
Description |
Zones |
List with all Zones defined for this object |
Add |
Adds a new Zone |
Remove |
Removes the selected Zone |
Blinks every (ms) |
Defines whether text and background of a Zone blink when this object's value is inside a Zone's interval |
Message |
Text of a message displayed when this object's value is inside a Zone's interval |
Alignment |
Defines a text alignment |
Font |
Defines a text font |
Background Color |
Defines a color for Zone's background |
Transparent |
Defines if this object's background is transparent when this Zone is active |
Default zone |
Defines the selected Zone as object's default Zone |
Blink |
Defines if this Zone blinks when this object's value is inside a Zone's interval |
Minimum |
Minimum value for this Zone |
Maximum |
Maximum value for this Zone |
Tip |
Displays a help text for this Zone |
Example |
Displays an example of this Zone's behavior at run time |
