Limitations of Demonstration Mode |
Without a product key, Elipse Power can be executed in Demonstration, or Demo, mode, which is useful for product evaluation. In this case, the following limitations apply:
•Allows saving projects with up to 20 I/O Tags
•Does not allow working with servers in Hot-Standby mode
•Does not allow working with Remote Domains
•Only allows communicating with one Level 0 (zero) I/O Driver, without Tag limitations. Drivers with a level greater than 0 (zero) are not allowed
•Does not allow access to Domain configurations, available on the E3 Admin's Domain - Options contextual menu on Windows Notification Area
•Only the first image of each category in the Symbols Gallery is available
•Only allows opening one Elipse Power Viewer or WebViewer
•The maximum execution time of a Domain is two hours
•Only allows recording up to 20 I/O Tags on a Storage object
•Allows access as an OPC Server
•Allows executing a playback of the last six hours of data, relative to the current server time, with an unlimited number of Tags, and all playback resources enabled
•Does not allow using E3 Admin's Export Users tool
•Does not allow using Elipse Power Studio's Import and Export tool
•Allows using up to 100 Measurements
•Allows electrical models with up to 20 inputs from the Power Flow module
•Allows electrical models with up to five Breakers participating on the Load Shedding module
•Does not allow using the State Estimator module
•Does not allow using the Distribution Load Modeling module
•Does not allow using the Self-Healing module
•Allows using up to two Substations
•Allows using up to four Feeders
•Allows using up to two Inverters
•Allows using up to four Photovoltaic Arrays
•Allows saving electrical models, that is, files in EDB format, with up to 20 devices
